- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
The TRIM command has the cut line beyond the frame
Video to see the problem The trim command works incorrect when I want to trim multiple lines. But when I trim 1 object, it trims correct, by the lines. UCS is not too far (can see in video)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are the second one i read about that issue.
Your Video is good, but not perfect (the commandline is not visible fully, the video started a bit to late..)
next time it would be welcome to see a AutoDESK Screencast with recors command and timeline.
For AdeskProducts really the best way: https://knowledge.autodesk.com/de/community/screencast
I guess you work normally, but it won't help you if I say "99% don't have the problem".
So how can we get to the bottom of this?
Please provide an example DWG, preferably the one from the video.
And your current settings too!
After you've created and saved the sample file,
start command: SYSVDLG, [SaveAll ..]
If the command is unknown to you, go this way:
Command: LOGFILEON
Command: SETVAR? *
then take the logfile from: LOGFILEPATH
(the name and the logfile you can read from LOGFILENAME)
Share your DWG and *.svf (or *.log) files with us. ZIP -> Attach
The video was (and is?) available for me, attached as zip again
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
See your other thread. Avoid posting the same question twice. Someone with the same problem who finds one of the threads may not know there's a solution on the other, and someone who has a suggestion to offer on one of the threads may not know that the same thing has been suggested on the other.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
