BeKirra
en respuesta a: emmakayne
Without seeing your drawing file I guess there are 2 possibilities.
1. the line type scale in model space is different to the one in viewport (in your layout).
   Have a look system variables LTSCALE, CELTSCALE and PSLTSCALE in HELP (Press "F1" key)
2. layer states setting. Some layers are turned off in model space when they are on in the viewport.
   Double click inside of viewport then type LAYER to open layer manager. Carefully check columns of "On", "Freeze", "New VP Freeze" and "VP Freeze" in the dialog for all layers.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
