12-03-2020
11:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-03-2020
11:55 AM
@zoeQL4SR wrote:
.... it's visually frustrating to have them show up as selected even if they aren't moveable. ....
Editing something [such as your example to Move it, or Copy/Erase/Rotate/Scale/Trim/Extend, etc.] is not the only reason you might want to select it. Suppose you want to use something in your Xref as a Trim or Extend or Hatch boundary? You can use things on locked Layers for those purposes, but would not be able to if you can't select them. [However, I find in quickie trial that you can't use things on locked Layers as the path in Extrude or ArrayPath, and possibly some other things I didn't try.]
Kent Cooper, AIA
