12-02-2020
04:54 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-02-2020
04:54 AM
linetypes as a standard are acting as annotative objects, meaning that they will maintain the same visual fidelity in model space as across several viewports in paper space.
You can change the scale of your viewports in the properties palette (when selecting a viewport). But you will see that the actual fidelity of your linetype will not change.
If you wish your linetype to scale together with the scale of your viewport you can change the PSLTSCALE variable (which you can also find in the details of the Linetype Manager (command: LINETYPE))
