11-26-2020
04:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-26-2020
04:00 AM
Hi @Anonymous
You can select multiple annotative objects and then use the command "AIOBJECTSCALEADD" to add the current scale to the object and to remove the scale you can use the command "AIOBJECTSCALEREMOVE" and command "OBJECTSCALE" to add other scales to multiple annotative blocks![]()
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
