- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi guys,
I have a pattern which I want to turn into a hatch, but I don't have knowhow to do it through CAD LT and I don't have full CAD available to me right now. Can I ask one of you lovely people to help turn the attached pattern into the hatch file?
Thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
How important is the specific angle of the ends? Because of the way linesets are defined in Hatch pattern definitions, it would be a lot easier if that could be tweaked [sharpened] just a little so that the red piece lies along a continuation of the green piece:
It would make this much difference:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If it makes sense to do that slight adjustment then go for it. Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Never mind -- it's not too far before an aligning edge occurs, so it's just a matter of a fairly long pen-up [negative-number] designation at the end of the diagonal lineset code lines. Try this [minimally tested]:
;; TEST.pat -- only ONE definition, called *TEST [copy to separate file with real pattern name]
*TEST, description here if desired
90, 0,0, 11.75,1, 10.5,-13
231.34019175, 0,0, 14.79746394,0.31234752, 1.60078106,-73.63592873
308.65980825, 0,0, 14.79746394,-0.31234752, 1.60078106,-73.63592873
NOTE that while this code window doesn't allow it, if you put this in a .pat file of its own, it needs to end with a hard return / blank line, not just at the end of the code content. And the file name [not including the .pat filetype ending] must exactly match the pattern name defined in it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for sending this, but it won't load the hatch. I can see it within my hatch drop down menu but wont' select it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Got it! I did have the space there but I had to remake the file and it ended up working.
Thanks!
