11-10-2020
02:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-10-2020
02:35 AM
The Object Coordinate System methodology is somewhat unintuitive. It was originally designed for computers with far less resources. That notwithstanding, it is a well thought out and makes better sense when fully understood.
From your other post we can see that you are automating a task – what language/approach are you employing? All the AutoCAD programming APIs have functions to assist the translation process. If you are working outside of AutoCAD, you will need to write those yourself.
Clarification on the issue above will assist the effort to present good advice.
May your cursor always snap to the location intended.
