pendean
en respuesta a: jetted4
It is odd indeed: are you remoting into your office computer to work that way, or is your home computer standalone and you simply VPN into the server to access the files?
Or some other setup altogether.
Is it always the same DWG file(s) that do this?
Which PDF driver are you using?
What is your AutoCAD version as listed in your ABOUT command?
What is your OS?
