@sergiolordelo342V2 wrote:
 I am open my architectural dwg, but it doesn't appear, because it became invisible.
- Did you check the layer status (all needed layers must be On and Thawed)?
- Did you a Zoom Extents? If so, did you check the visible range of coordinates? (maybe you see a very large area and your geometry was reduced to a small point)
- can you select some geometry using the qselect command? (you should see at least some grips)
- what happens if you change the view direction (Front, Top, Back, ...)
This is all a poking in the fog. I don't still have a firing idea what could be causing your problem ... :cara_de_decepción:
Jürgen Palme
