acicci
en respuesta a: RobDraw
I randomly turned off a bunch of cursor related options (the ones I could think of). Turning of dynamic input works, but I don't consider not using a feature that I like to be a fix.
I don't know what changed. Before I never had this problem, then my Insert Block Palette stopped loading blocks and the recommendation from autodesk was to restore my program to defaults. After doing that My block Insert Palette was fixed but this weird 1/2 second of mouse delay on all creation / dimension commands kicked in.
There is an additional weird behavior I can add that I only just noticed, when I finish a command (that causes this issue) my cad cursor will display as the microsoft pointer until I move it. This leads me to believe that for whatever reason CAD is losing priority after finishing these commands, and then being given it again after something checks to make sure I'm using it.
