acicci
2699 Vistas, 14 Respuestas
Cursor Delay - CAD 2021
I'm experiencing a cursor issue in CAD. I've managed to trouble shoot it down to a few issues / causes
The Issue:
Certain commands cause my CAD cursor to disconnect from my regular mouse pointer. By this I mean that if I use the rectangle command. when I finish the rectangle the CAD cursor will remain where it was when the command ended while I move the mouse. The mouse still registers the movement, showing as the typical Microsoft arrow. After maybe half a second, the cursor snaps back to the mouse and everything is normal.
Specifics:
This only happens with certain types of commands. Basically any draw command that produces a new entity; Circle, Rectangle, Pline, etc, as well as dimension commands cause this issue. manipulation commands however (move, stretch, etc) are fine.
Current Fixes:
There are currently two scenarios where this doesn't happen.
1. Turning off the block insert palette that was introduced in (I believe) Autocad 2019.
2. Turning off DYNMODE (Setting it to 0. setting it to 1 will stop this issue from happening with draw commands, but persists for dimensions).
Note: If I don't have the insert palette open, I can run DYNMODE at 3 with no cursor issue. Likewise if I run DYNMODE at 0 I can have the insert palette open with no cursor issue. I don't consider these to be fixes because I want to use the tools that CAD provides and not using those tools seems self-defeating.
Thus far I have tried:
Resetting CAD to defaults
Reinstalling CAD
Any ideas?
Etiquetas (1)
RobDraw
en respuesta a: acicci
This sounds like a hardware issue. Try disabling anything having to do with the cursor (There are a lot of them.) until it behaves normally.
Rob
acicci
en respuesta a: RobDraw
Thanks for your response!
Could you be more specific? I don't know what you mean by disabling anything to do with the cursor. Are you referring to dynamic input? Also, for what it's worth, I've only started having this problem recently, and my cursor behaves totally normally in every other piece of software I own.
Regards
vinodkl
Hi @acicci
Try turning "ON" the "Hardware acceleration" and see if that fixes the issue. Type in the command "3DCONFIG" and turn it "ON".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
acicci
en respuesta a: vinodkl
Hello and thanks for the response!
I already have hardware acceleration turned on. I tried turning it off but found it made the program less snappy.
vinodkl
Are the options inside the "hardware performance" enabled? If not then enabling them would make any difference?
acicci
No sorry, no combination of hardware acceleration affects seems to have an affect. Only those options I listed in my original post seem to work for me. I'm debating doing a full reinstall (cleaning out the registry as well) but I'd rather avoid that if possible
RobDraw
No. I was being generic deliberately as there are a lot.
Among many others. OSnaps, Object Tracking, Tool Tips, etc., etc., etc.
It's worth more than you appear to think. What has changed?
Good.
Rob
vinodkl
Hi @acicci
Try the solutions listed in this article: Cursor is slow, jumpy, or jerky in AutoCAD
If all of the solutions listed doesn't work then you need to clean reinstall AutoCAD or else you could wait until someone in the forum comes up with a solution to your problem:cara_con_una_leve_sonrisa:
acicci
I randomly turned off a bunch of cursor related options (the ones I could think of). Turning of dynamic input works, but I don't consider not using a feature that I like to be a fix.
I don't know what changed. Before I never had this problem, then my Insert Block Palette stopped loading blocks and the recommendation from autodesk was to restore my program to defaults. After doing that My block Insert Palette was fixed but this weird 1/2 second of mouse delay on all creation / dimension commands kicked in.
There is an additional weird behavior I can add that I only just noticed, when I finish a command (that causes this issue) my cad cursor will display as the microsoft pointer until I move it. This leads me to believe that for whatever reason CAD is losing priority after finishing these commands, and then being given it again after something checks to make sure I'm using it.
acicci
Unfortunately I've tried all of those fixes as well. It's looking more and more like I may have to do the clean reinstall
acicci
Well as per my usual arrangement with issues on Windows, the nuclear option fixed it.
I deleted absolutely everything to do with CAD on my computer.
I removed all autodesk programs as well
I deleted the associated registry keys and folders
After a reinstall the problem has dissapeared
Cheers to all of you
vinodkl
Great to hear that your problem has been resolved:cara_con_una_leve_sonrisa::símbolo_del_pulgar_hacia_arriba:
pendean
Post a screenshot of your ABOUT command pop-up please.
And your GRAPHICSCONFIG command pop-up too.
TIA
acicci
So believe it or not I was able to drill down deeper into this whole rigmarole
The problem specifically lies in the august 11 2021.1 update. If anyone else is experiencing this issue; UNINSTALL THAT UPDATE
Cheers again!
