a.blackMV4H7
en respuesta a: Anonymous
Have you looked into using annotative scaling? If your dimension and text styles are set to be annotative the text size should remain consistent regardless of the scale of your plan. Take a look here if you're interested.
Otherwise you would have to set your text to be a multiple of your DIMSCALE value * the height of the text in your dim style, if I follow you correctly. So if your text is 2.5 in your dimension style, and your DIMSCALE value is 10, your text style height would be 25.
