496 Vistas, 7 Respuestas
10-27-2020
08:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-27-2020
08:55 AM
long time user needing help with new commands
I have been using autocad for around 30 years. Just had to upgrade to new version due to computer failure.
The complete changing of the commands is driving me nuts as most of the commands I use to use no longer work or have been redesigned. I have been able to work around most but...
I am looking for a way of adding text to the drawing in the same style as a dimension. I use to use dim Leader and then select the same start point and it would allow me to add text without the leader. I have tried mleader and bleader without success. When I use them I then have to go back and explode the leader then delete the arrow and line. Is the a command that allows me to add text using the dimension style & scale without the leader?
Jeff
