10-26-2020
11:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-26-2020
11:04 AM
If you have Autosave turned on in your current AutoCAD profile (see Options), and if the increment is sufficiently frequent, then there may (should) be automatically saved "versions" of the files you have worked on. The location for these files is determined by the Automatic Save Files Location on the Files tab of Options (also part of the current profile). You can try the Drawing Recovery Manager to find them, or you can use File Explorer to browse the folder "manually". The files will have names similar to the files you worked on, with random characters added at the end, and may appear with both BAK and SV$ filename extensions. They are valid DWG files, so renaming them with a DWG filename extension enables you to open them in AutoCAD.
