996 Vistas, 4 Respuestas
When in monochrome one color is still showing (orange)
A year ago I was on a project and I needed to print out one color specifically orange in color when printing in monochrome, I know this is a setting that you can turn on before plotting your print but after the last update, I do not see how you can turn on and off specific colors in monochrome before plotting.
Patchy
en respuesta a: Anonymous
Go to plot and change that color from black to orange, it doesn't matter the .ctb is monochrome
change it and give it a new name.
cadffm
Use another Plotstyletable where your plotstyle(your color) is set to "by object",
or if you want to use monochrome.ctb
use a TrueColor value for your orange color.
CTB plotstyletables incl. plotstyles for ACI colors only, so every truecolor will print in this color and isn't controlled by your ctb plotstyletable
Sebastian
dmfrazier
en respuesta a: Patchy
"...and give it a new name."
Yes, you can name it "orange is the old black".
I could be reading your post title wrong, but it seems like you have one color/layer/object plotting orange instead of black, and you want it to be black? Look at the properties of the object in question, and if it is set to a RGB value (ie: 0,0,0 for true black or 255,255,255 for true white instead of a single number like 0 for black or 255 for white, etc.) change it to any of the standard 256 colors and it should plot black after that.
