- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have two surfaces that are slightly curved, but are the same distance apart at every point. I'm wondering if there is anyway to get my loft between these two surfaces to be a solid.
Thanks in advance.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you can try THICKEN command and put a proper thickness value . >> Click <<
Command: THICKEN
Select surfaces to thicken: 1 found
Select surfaces to thicken: Specify thickness <0.1000>: .05
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Check the attached dwg. I used the following steps.
1. surface patch top and bottom open ends
2. sculpt.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you for the replies. I ended up sculpting the surface using the profile I needed and thickening that surface one inch.
