office6PUWT
3755 Vistas, 1 Respuesta
Data Extraction and .dxe files
Are .dxe files the only available option from autocad. The are not opening properly for me in excel (see attached pic). Is this problem fixable in autocad or excel please?
Luke
vinodkl
en respuesta a: office6PUWT
Hi @office6PUWT
.dxe file is actually the template file used to extract the data from drawing in AutoCAD. You are not supposed to open that in excel.
You need to use that .dxe file as a template when you run the "DATAEXTRACTION" process:cara_con_una_leve_sonrisa:
Here is a video on how to extract data from drawing: All about Data extraction in AutoCAD
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
