pendean
en respuesta a: shil143
No LISP, no 3rd party add-on as far as I can tell, the process requires so much user input its not viable.
I suspect you would have to write an overly complex VLisp/VBA/.NET program that works against a list (not a DWS) that contains all the to/from info you'd have to pre-create from all of the files and match up. Any variation in any of the outside files then you need to re-examine each and rewrite that to-from list manually, then rerun the routine.
HTH
