Bob_Zurunkle
en respuesta a: MarkFitz
You shouldn't have to, just as you shouldn't have to rename every block that represents say, a light switch.
One tip is to have your first layout tab all set up including for border and output (plot settings). Then you can copy that tab by right-clicking the tab name, and choosing the copy option. everything will be duplicated including the settings and the border.
There are at least two ways to control the info in the title block. One is to have it where you update it by opening the block and filling it in before saving and exiting the block.
The other is my preference, which is to have the block populated by fields. You can create custom fields which you fill out using the Drawing Properties. That eliminates having to revise the block itself. I have a field in there that displays the filename as the Job Number, and another that displays the name of the tab as the sheet number. This happens automatically. I also use them to display a view's scale automatically if it changes.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :cara_con_una_leve_sonrisa:
