- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Autocad othotmode multipe clicks at once
I used to use F8 button to activate/desactivate ORTHOMODE with no problems whatsoever, but recently I've been having issues with multiple clicks. If no Object is selected I can press the F8 button and it will work just fine, but if any object is already selected and I'm in the middle of dragging it, if I press the F8 it will get extremelly laggy and from the command window I noticed what actually happens is that the one click it's giving multiple ortho on/ortho off at once. However if I click on the ribbon button it works fine as well, even in the middle of dragging. Happening in two different pcs, the problem started after both opened the same faulty file. Definetly not a keyboard issue, as stated before it's happening in two differente pcs, other keyboars where tested and the problem won't occur if no object is being dragged, regardless as to wether I'm using move command or dragging the object from a vertice. Appreciate any input, cheers!
