rushabhthakkar_910
en respuesta a: Anonymous
Do you want to say that you want to draw a Circle in 3D in AutoCAD ....?
And when it is not.matching your Plane...? I mean the Circle should get drawn in Z-X Plane but it gets Drawn in X-Y Plane...?
If that's what you are Looking for then, Ellipse is the Right Command to Move forward with.... Under Ellipse is an Option of Isocircle..... Try using Isocircle... I think it will solve your issue.....
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
