353 Vistas, 1 Respuesta
AECTOACAD Issues
I'm getting some strange behavior when using the AECTOACAD command.  After several successful exports I am getting some types of blocks that explode in random 3d locations. (Specifically these blocks are HVAC terminations, i.e. fans, louvers, etc.) Furthermore, it looks like there are copies or arrays being created, because there are way too many. If my image uploaded correctly, you can see the green equipement items that should be attached to the pink ducts. Any ideas?
Thanks!
Alfred.NESWADBA
en respuesta a: Anonymous
hard to say without having the drawing to play. So some questions:
  • What software did you use to create the drawing?
  • What version of AutoCAD do you use when running the export?
  • And have you tried to run command _AUDIT before?
  • At least: turn on PROXYNOTICE, then load the drawing and see which object types are all in the drawing made by vertical products or 3rd party applications.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
