cheryl.buck
en respuesta a: RobinCris
Hi @RobinCris
The DXF file formats 2013 and 2018 (2018 is the lasted format, and is used by AutoCAD 2018-2021) are slightly different, so it would depend on what specific information you are using from the DXF. The vast majority will be the same, as noted by @cadffm .
One way to view DXF code is to open the files in NotePad.  I have done this to compare 2 files side by side.
Please let me know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
