- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
DXF 2013 vs DXF2021
I wrote a java desktop program that work straight on the dxf files.
It mainly use those objects (layer, polyline, line) with their properties
I wrote it 7 years ago and we still use DXF 2013.
I am starting to make a new version based on the same engine but I do not know if the dxf file with the basic object will be read the same way.
Is the object stayed the same?
If not, is the a place I can see the changes?
Please advice
Thank you
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
More important than the program is the file format ![]()
And the object data for simple drawing object in dxf2013 should be the same as in dxf2018, which is the newest file format for dxf.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
So you think the group codes and the main data tables do not changed?
Just new one been added?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
group codes doesn't change
! Possible would be "new added", but only for new features, an i can not remember about
newer things between 2017 and 2018 (up to 2017, dxf2013 the newest DXF format, since 2018 versions, dxf2018 is the newest format
What do you mean with "main data table" in detail?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
One Question
Why not testing yourself (it's good to aks other, but the first test - you can do yourself, or?)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @RobinCris,
The DXF file formats 2013 and 2018 (2018 is the lasted format, and is used by AutoCAD 2018-2021) are slightly different, so it would depend on what specific information you are using from the DXF. The vast majority will be the same, as noted by @cadffm .
One way to view DXF code is to open the files in NotePad. I have done this to compare 2 files side by side.
Please let me know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
[This post has been edited for clarity by cheryl.buck]
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
