lais.r.f
3123 Vistas, 6 Respuestas
Dashed polylines appear only outlined on model space
I have the following problem on my drawing: I have a few dashed polylines that appear normal in the layout, but show up only as an outline in the model space. That is, I see only an outline of the dashes.
UCS is set to world, view is set to current, visual style is set to 2D. All Polylines have no elevation. Linetype was set to some weird imported linetype, but I already changed them all to one of the autocad default dashed lines (DASHED 2 or so)
The weirdest bit: If I create a new polyline and set the same linetype and global thickness, it appears normal, solid. But if I try to match properties of the new line to the existing lines, the old lines remain hollow. In fact, if I match the properties of the newly created line to any of the lines that already existed in this drawing, the old lines turn to the same type and thickness of the new line, but hollow. The file was in a weird UCS (with a Z value, even though it's a 2D drawing) when I got it, but again, I fixed that and moved all polylines "down" so they have no Z value to them. An older version of this file, from before the UCS was set to world, seem to show the lines normally.
Anyone has an idea where the problem could be?
Etiquetas (4)
Etiquetas (1)
