cadffm
en respuesta a: cadffm
@cadffm wrote:
Open your (Sample)file, Command: PLOT, the upper right button start the Plotstyletable - Editor,select Plotstyle Color253 (or 8 for the both *GRID* Layers)Q: IS the COLOR mapping set to "use object color" ?
1. Answer: No, the Plotstyle Color253 is set print to BLACK.
    Please check this out!
2. Your Layers are set to 50% transparency, that's wouldn't be my setting, but ok.
    The Problem is: Your pagesetup is well set to print 50% (Plot transparency is turned OFF!)
What to do:
First test, open your file, PLOT command, Set 'Plot transparency' ON,
Try it again.
If this is also not what you expect, follow my hint about Color253 => Block in Plotstyletable.
But i am pretty sure someone who created this CTB did this because he wants to plot 253 as Black.
Ask your other users about the company standards..
bye
Sebastian
