09-29-2020
10:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-29-2020
10:19 AM
Hi @rudhamstile,
I found some information on the 3DConnexion website that this error occurs when the drivers for a Spacemouse have been installed and have been associated with the application.
They recommend reinstalling or restoring defaults on the driver, or disassociating the application in the driver settings.
In AutoCAD OPTIONS, under System, there is a section for pointing devices. Check to see that the Spacemouse or any of its components are not selected. I found this Autodesk Knowledge Network article for the settings available in AutoCAD for it.
Please let us know if that helped.
You can use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
