ВeekeeCZ
en respuesta a: JamieLeeAutodesk
As was mentioned before, this is not customize-able. You can set only precision.
Even with a LISP, it's not as simple task as set one or two properties. But definitely recommendable to learn at least basics of LISP.
But yes, the LISP can be a solution but with more complex algorithm. See the attachment. This LISP exports just an area to the command line. I does not mimic the LISP function, it's not that simple. If you need more properties to listed, just tell. Not sure how much if're versed with LISP, see the tutorial HERE if you need it.
Then the result would look like this:
The precision still honers the UNITS setting.
