JamieLeeAutodesk
645 Vistas, 3 Respuestas
I need help putting a comma in area section of command LIST
Hello guys
I'm new to this forum. I'm using Autodesk AutoCAD 2021 64bit on a Windows 10 machine. Hope you can help me out:
When I use the LIST command, I can see the area of the object I used the command on. But.. there's no comma there, what I need is a comma to appear 4 digits before the dot.
Example: in the following picture you can see the area of the object is: 3.35 (rounded + in meters in a model of 1:100 scale), but it appears like "33599.99" while I'd like it to appear like "3,3599.99" with a comma 4 digits before the ".99"= this way it's easier for my eyes to see the meters (3) and the centimeters (3599) that are before the ".99" at the end in that example..
Another example: in the following picture you can see the area of the object is: 115.65 (rounded + in meters in a model of 1:100 scale), but it appears like "1156352.23" while I'd like it to appear like "115,6352.23" with a comma 4 digits before the ".23" = this way it's easier for my eyes to see the meters (115) and the centimeters (6352) that are before the ".23" at the end in that example..
I tried "playing around" with settings in "options" or even in "user interface settings" and couldn't find a way to put that comma as described above. Can it be set up through settings or do I have to load some LISP file to AutoCAD to recognize this and put that comma?
I'd like your help
And.. if a LISP file is needed please guide me what to write into it + how to create the script into a LISP file, as I have no idea how to do it
Thank you very much in advance!!
Jamie.
Etiquetas (2)
