- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello guys. I'm having a pretty serious problem and can't figure out how to solve it. I'm using the student version of AutoCAD, and doing a job mapping two really big farms. They're about 35k hectares (86k acres) each, on separate files. The blueprint itself it's not really complex, but maybe a bit heavy. I have finished my job, but can't collect due to this problem when trying to plot.
I have tried on 6 different computers, purged, audited, exploded blocks, copied it into a new empty file, deactivated hardware accelerator, tried EXPORTPDF. Same result.
I uninstalled and reinstalled (2018 version), tried on 2020 and 2017's versions. Always the same sign when I hit Save: ''A software problem has caused autocad to close unexpectedly'' with both files.
I have no trouble on sharing the file uppon request, if you think you may solve it!
Cheers
Santiago
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Solved! I was able to plot by two means:
1) Downloading Autocad 2021
2) Downloading PDF Creator to convert.
