- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
most common methods of rotating the view in a viewport
Working on a large project that covers roughly 80 acres with a lot of small things happening all over the site. When assembling my sheets, I have forever used the method of rotating my ucs to whatever object I want horizontal in my viewport and then use the plan command and choose current ucs to rotate my view. Solid process in my opinion, however, with such a large site and many alignments and civil 3d object labels, the plan command zooms to extents and it is necessary to zoom and pan and regen all repeatedly to find my exact location.
Just out of curiosity, what are the most common methods used to rotate a view in a viewport? I'm guessing dview-twist is right up there? What are the other ways of accomplishing this? Are there lisp routines available that aid in this task?
The reason I ask, is there a way to rotate the ucs in a viewport and then rotate the view to the current ucs without zooming extents?
