3307 Vistas, 4 Respuestas
When inserting block, it appears too far away from the crosshair
I have been using AutoCAD 2021 for a month so, forgive my lack of knowledge. I am second year Civil Engineering student.
Anyway, whenever I insert a block, it always appear too far away from the crosshair. I've tried everything I have read here in Forum as well as in Reddit however, all of the suggestions were not working.
Attached below is the proof of my problem:
The yellow circle is the block I did. Look at the distance between the block and the crosshair.The yellow circle is the block I did. Look at the distance between the block and the crosshair.
Badly needed your help. Big thanks!
