gccdesign
402 Vistas, 3 Respuestas
Copying / pasting an object like a line from one DWG to another dwg also pastes dimension styles and text styles.
Using Autocad 2021.1, when I copy with base point an object like a simple line or a point and paste it into another DWG file, it also pastes dimensions styles and text styles. This is even though no dimensions nor text objects were selected or copied or pasted.
This has been the case for quite awhile in Autocad, not just 2021.
Autodesk support tells me this is a limitation of the software.
I don't like to get drawings cluttered up with random dimension and text styles from other drawings.
It's a lot of extra steps to purge and delete these styles later.
It also pollutes office standards and you can start getting other standards mixed up as more people use files with these added styles.
Anyone know a way to avoid this happening?
GChapp
