- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Publishing Issues - Objects change lineweight after publish more then one page
The issue that I am having with a user is that when they plot one page they get no issues, but if they publish multiple pages to a PDF some of the objects are changed to bold(thicker line weight).
I have attached two files which have been published from two separate computers. Both computers run the same software for this process to take place and one works and one does not.
I have been scratching my head about this for months and have not been able to find any assistance.
I need to come up with a solution for this problem because it is effecting my staff's ability to get their work done.
Thank you to anyone who can assist me in this.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
How are they so different exactly? Not seeing it on my screen.
FWIW if two computers plot/publish different lwieght settings, it usually means both computers are using different settings or drivers or something else with the same name but not much else: that's just a fact.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is one published in the foreground and the other in the background? Or is one with PLOT and the other with PUBLISH?
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Send a screenshot of the plot settings that are used for the single PDF, and the batch plot (publish) pdf. Make sure you are using the same CTB files and settings for plotting an individual PDF and publishing multiple drawings. Are both computers on the same server or are they in different offices? I typically will use a standard "Page Setup" that is applied to every drawing whether you are plotting individually or for publishing multiple drawings. This is a fairly fool-proof way of plotting consistently.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good day,
If your looking at the plan itself you can see the borders around some of the text and objects changes to a different line weight which is shown on the incorrect file.
The correct file has the proper lineweight but I am attempting to find the settings that make those changes so that I can match them and get this machine running.
It has been an arduous thus far.
Thank you for your input.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good day,
The single page is through Plot and the multiple page is through publish.
I am using my own machine to troubleshoot the issue and my machine works as it should be on the other but just trying to find the settings that will make them match in output.
Thank you for your assistance.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you try Publish without background plotting?
Jimmy Bergmark
