09-16-2020
07:11 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-16-2020
07:11 AM
My guess is that this happens only with lines that are horizontal within your tolerance value. Some [considering those drawn from left to right] are going to be just barely over 0, at angles such as 0.OOOOOOOOOOO371 radians, and some are going to be just barely under 2pi, at angles such as 6.283185307179426 radians [instead of 2pi to the same number of decimal places = 6.283185307179587]. Those just barely under are going to remain just barely under pi after your
(rem (vla-get-angle vlaEnt...) pi)
functions, so the comparison to barely over 0 will fail.
I think you need some kind of (or) situation to cover that possibility. EDIT: There may be a more concise way, but this should do it [untested]:
;if angle is equal to reference, turn to color red
(if
(or
(equal refangle comangle 1e-12); basic same-direction check
(and ; straddling horizontal?
(or (equal refangle 0 1e-12) (equal refangle pi 1e-12))
(or (equal comangle 0 1e-12) (equal comangle pi 1e-12))
); and
); or
(vlax-put-property vlaEntcom 'Color 1); then
(vlax-put-property vlaEntcom 'Color 2); else
); if
Kent Cooper, AIA
