Moshe-A
en respuesta a: minh.dxuan
@minh.dxuan  hi,
Attached a lisp command called RDD to do what you want. place the file (rdd.vlx) in your lisp folder and load it. type rdd to run.
for dimension it accept any type of dimension.
for text it accept text + mtext. if you pick mtext be aware the whole text value is replaced by the dim value.
the result text format is comply with the selected dimension dimstyle. if the selected dimension has dimension overrides, they will not affect the result.
enjoy
moshe
