- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Copyclip Error
Each time I try to use Copyclip when I paste into drawing it pastes this /tmp/A$C46751236.DWG Has anyone had this problem? Would love to solve as its very frustrating!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you can refer to these LINK and LINK and see if helps. thanks
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Please confirm that you have select objects when Copyclip ?
Command: _copyclip
Select objects: Specify opposite corner: 3 found
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes I confirm I am selecting objects/lines/blocks/text - anything in drawing but nothing will copyclip.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This is your copyclip.
Using the clipboard will create a new dwg by copy or cut action with a name like that name,
Paste action insert this dwg model content.
Draw a circle, copyclip the circle,
use autocad to open the new a****.dwg file.
Command Object last
Is your circle there?
Okay.
Start a new empty file,
Command PasteOrig
Zoom Object last
Is your circle there now?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
if Ctrl+V not work , what about Ctrl+Shift+V ( _pasteblock ) ?
Imad Habash
