f.lawton
en respuesta a: f.lawton
I found the problem.
I kept noticing layers, whose text appeared gray and belonged to the xrefs, unexpectedly kept showing up in my host file's layer property manager as being turned off. (turned off, not frozen) So I turned them on and updated the associated layer states. Everything works good now.
When I set up my host file originally, I created a specific layer for each xref, and I made each of those current before i attached the associated xref. I assumed, for some reason, that the entire xref with all of its layers would be controlled by the status of that single host file layer.
