344 Vistas, 2 Respuestas
Layer Control & Selection
Hi There
I'm running AutoCad 2018 and I having an issue with the Layer Control.
In the Layer Properties Manager I Right Click to get a menu for controlling the Layers.
If I select "Select All But Current" and turn off the rest of the Layers the Current Layer also Turns off!
Also, if I try to turn off all Layers, I get a warning that lets me know I'm about to turn off the current Layer with an option to turn the current layer of Yes or No. Even if I click the No option (ie keep the Current Layer On) it still turns it off.
I know it is a simple matter to just turn the Current Layer back on again but its getting to be a real pain.
This issue has not always been the case and has just started recently.
I'm not entirely certain when this started and its only a minor thing but when the pressure is on and you are trying to work quickly it does become an irritation.
Can anyone suggest a method to ensure that Selecting all but Current Layer actually works?
Many thanks in anticipation of your help.
