en respuesta a:
11:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-28-2020
11:30 AM
If I understand the question correctly, answer is: without using either lisp or VBA you can't convert an arc directly into a "straight" line or polyline.
By using command "pedit" and selecting the arc, you will have a polyline-arc that will have the exact (to whatever you have your precision set to) same length. If you use the grip-edit option on the polyline arc and select "convert to line" you will get a "straight" polyline equal to the "straight-line" distance between the end-points of the arc.
The total length of arc and polyline-arc will both display in properties window or quick properties (or by using "list" command) if you just need that number to work with.
Does this help? If not, what exactly are you trying to do?
