Tiana_Y
en respuesta a: Anonymous
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum! Try selecting the arc, right click and there should be an option to select "Convert to Polyline". As a warning, I believe this will explode the arc and I am not certain it will be the same length.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
