- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Title block information into Sheet set
Our company is relatively new to using sheet set and even newer to using sheet set with Vault. We have many drawings that are saved for our clients (thousands for some clients) that get re-used into different projects through the years. The issue we have is when we have a new projects for these clients, we go out and grab all of these drawings from our server, put into a project working folder. Our title blocks reference fields in set so now every one of our drawings will blank out these fields unless we re-type all of these fields into the new sheet set, but this is for many drawings sometimes hundreds per customer.
I guess my question is if that all makes sense, how can we reuse drawings and not lose the information in the title block but also NOT retype everything in sheet set with every project.
I hope that makes sense but I can elaborate if needed. Thank you for the help.
