vinodkl
en respuesta a: madhuryya_prakash
Hi @madhuryya_prakash ,
Instead of using "PAN"  try using "-PAN" wherein you can specify the distance of pan. First set the ground floor layout and then copy the layout. Measure the distance between the floor plans in modelspace and keep a note of it. Now activate the viewport of the copied layout of the ground floor and then enable ortho (F8) and then type in the command "-PAN" and then select the basepoint and then move in the opposite direction your floor plans are placed and then type the distance between the floor which you have measured earlier:cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
