madhuryya_prakash
484 Vistas, 7 Respuestas
Plotting of sheets in layout(not batch plotting)
Hi ,I have different floor plans of building set at a specific distance from each other in the model space.
My query,Is there a solution while composing sheets in layout space I can type a certain command, so for example ground floor appears in ground floor sheet layout(considering I have created the ground floor sheet layout),first floor appears in first floor sheet layout (considering I havecreated the first floor sheet layout) and so on, without actually panning inside the viewport and adjust the floor plans to appear in the desired page.
