liammullins77
6152 Vistas, 15 Respuestas
no ribbon... _ribbon Unknown command "RIBBON".
Hi there,
I dont seem to be able to get the tool palette ribbon to load.
I can open the Menubar fine.
Command: MENUBAR
Enter new value for MENUBAR <0>: 1
but when i go Tools>Palettes>Ribbon i get this...
Command: _ribbon Unknown command "RIBBON". Press F1 for help.
have tried To Reset the Application to the Default Settings as per link https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Au...
Etiquetas (2)
Etiquetas (2)
pendean
en respuesta a: liammullins77
imadHabash
what happen if you type in command line RIBBON command ?
Imad Habash
liammullins77
en respuesta a: imadHabash
same issue
Command: RIBBON
liammullins77
en respuesta a: pendean
I tried "Unknown command" when entering commands in AutoCAD but it doesn't help and everything is already at the correct settings.
liammullins77
Im running the latest Autocad version on windows 10. (it is a student version but i think it functions exactly the same)
I have also tried to reset the CUIx per https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Interestingly the command shortcut still seems to exist. when I type RIB the drop-down menu shows RIBBON as an option but it still wont execute  - Unknown command "RIBBON". see attached PNG for example.
the program seems to freeze for a few seconds before saying Unknown command.
Could this be a workspace issue?
cadffm
Select another Profile
OPTIONS/PROFILES/..
or start with a new profile
Start Acad with parameter "/p "TESTprofile"
Read your help about it [F1]
Sebastian
ennujozlagam
you can try this in the command prompt type RIBBONCLOSE > enter > type again RIBBON > enter and see if helps. thanks
pendean
Change workspaces and see if that helps
Otherwise you have a major reinstall ahead of you, then you also need to ensure you have the 2020.1.3 update installed.
liammullins77
I have tried a full delete of all autodesk products and a registry key clean as well as deleting all temp and leftover files. still no luck resolving the issue and i get the same Unknown command "RIBBON".
pendean
You have something else going on https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Might be time to take your computer to a repair shop if a factory reset is not an option. back up fully first.
edgar_pacoMTSRN
I have been dealing with this for months and still cannot get the Ribbon back.
Does anybody knows how to fix it?
I did a clean uninstall deleting temps, registry and all that, re-installed it but still the same..
I have tried also all the troubleshooting steps but nothing seems to work.
Please help!!
pendean
en respuesta a: edgar_pacoMTSRN
@edgar_pacoMTSRN wrote:
I have been dealing with this for months and still cannot get the Ribbon back....
Lots of troubleshooting tips are found in here, how much of it have you tried so far
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Ribbon-and-toolbar...
OR... here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
edgar_pacoMTSRN
I cannot open those links, both show "404 error".
I tried a lot of the tips, trying to reset to default, type "Ribbonclose" or "ribbon" and many more with the same results,
I tried to do a clean uninstall and then reinstall it with Administrator rights, deleting the registry entries...
Almost everything i found related to "unknown commands" i had tried with no luck
liammullins77
Hi, the solution I ended up finding was to reinstall windows and factory
reformatting the pc. It’s by no means the most elegant solution but it
worked. I don’t remember which of the above trouble shooting I tried but I
do remember trying many different solutions from both Autodesk and online
forums and non of them worked.
hi, do you install the software again?
