R_Tweed
en respuesta a: Patchy
There seemed to be an issue with using regions as sections. Just a guess that your regions weren't created from a closed polyline.  I used polylines because I can then determine if it's closed or not through the properties palette.
I made polylines by selecting each vertex in the screencast just to assure myself the first time that there would be no additional segments and if you notice I use the close feature to end my polyline command.  I went back through a second time and converted your regions to polylines and it lofted without any issues.  See <screencast>  and attached dwg.
