- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Good Morning.
I am having a similar problem. When trying to open by original file I get a pop-up saying "Drawing file is not valid." So I tried to go to Explorer and open the .bak file. I chose open with AutoCAD LT Application. FYI, I'm using AutoCAD LT 2018. I tried searching for AutoCAD DWG Launcher (which is an option I get with I choose open with on the dwg file) but nothing comes up. After doing this I tried making a copy of the file and changing the name and giving it the .bak extension. When I try to open that with AutoCAD LT Appication I get a pop-up that says "Cannot fine the specifice drawing file. Please verify that the network drive is available and the file exists." This all happened this morning. I was working in this file, I saved it, and then closed it (as well as all the programs I had open at the time)...I had to reset our server. After the reset I tried to open the dwg file and that is when I got the "invalid" pop-up. I am not having trouble opening any other files, just this one. And I tried to open it on a different computer but got the same "invalid" message. This file has a lot of needed drawings in it.
Please help!!
Sincerest thanks for any and all help.
Tracey
