fatal.error
en respuesta a: Anonymous
As @Kent1Cooper stands, all of the 3D Polyline vertices must be in the same plane (coplanar). You can check it by converting that 3D Polyline into a Region. If you get "0 Regions created" as result, the vertices are non-coplanar or the loop is not closed.
