08-10-2020
06:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-10-2020
06:56 AM
@Anonymous wrote:
The new problem, When I extrude the 3D poly line It doesn't extrude as a solid but as a mesh.
If you need to use a 3D Polyline instead of a 2D one because the points are not in the same plane, then presumably you will get a result that itself does not lie in a plane. If that's the case, you cannot Extrude it into a Solid, regardless of the MOde option you choose in the Extrude command. A 3D Polyline must be flat to be able to Extrude into a Solid.
Kent Cooper, AIA
