diego.haberle
en respuesta a: pendean
>>Have you already installed the 2019.1.2 update? It is required, the ABOUT command will confirm if you have it or not.
Yes, I have already installed the 2019.1.2 update, anyway with the about command I do not see if it is or not but I remember installing it, I use the Autodesk desktop application and in AutoCAD it appears that I have no updates available!
